Community Member
DFM 3.2 Critical Alarm Clear Notification
Does anybody know if there is a way to setup notifications for when critical events are cleared and not include information events being cleared?
Everyone's tags (1)
1 REPLY
Re: DFM 3.2 Critical Alarm Clear Notification
No, this is not possible.  All Cleared events are informational themselves.  If you want cleared events, you need to enable both Cleared and Informational.  However, you can create an event set which only includes the Critical events you want.  Then, you will only see notifications for cleared events pertaining to those Critical events.
196
