Webcast-Catalyst9k
DFM alert
LMS2.5. I noticed that DFM will send all the interfaces up and down alerts when it polls. How can I make it just send alert for one particular interface? For example I just want to monitor the wan interface, not vlan interface, not lan interface. But when add the device wan ip into common service and shows in the DFM, even the loop or lan interface down, it also will send alerts. Is there a way to avoid this? thaks
Bronze
Re: DFM alert
the alerts configured on DFM or device based, don't think, you can configure them specific to an interface.
Re: DFM alert
Go into device details and look at the interfaces or ports. You should be able to set the Managed State to False.
115
