Webcast-Catalyst9k
DFM and backup interface
I am using dfm 2.0.5 and on my routers I am using fr and virtual templates and ppp encap on them. For backup I am using dialers and dialer watch trigering. DFM does not recognize dialer as backup interface. Can I make DFM to see dialer as backup interface for virtual template/access interface?
thanks!
1 REPLY
Re: DFM and backup interface
How about this:
1) Create a new Interface Group called "PPP interface"
2) Add the following Matching Criteria
Type = *PPP*
3) Increase the Priority of this new PPP interface Group to a higher
level than the default group Dial on Demand.
4) Reconfigure.
5) Verify that there are now members under the PPP Interface Group.
In addition to modifying to group and adding the rule can you make sure you have done the
following:
1) The first thing would be to make sure the alert has been acknowledged in the Alerts and
Activities window
2) If you are still receiving the alerts you can als set the threshold value
ExceededMaximumUptime=0 ,this will disable this event (Given in on line help).
DFM->Configuration->Polling and Threshold -> Managing threshold
(for further details click on context sensitive on line help at this Managing threshold
screen).
This will only disable ExceededMaximumUptime=0 for the group it is applied to.
This can even be made finer by the creation of custom group with filters like
sysobjectid=" " which can create a group for those devices or even interfaces for
which "VI1 interfaces created automatically by IOS" and apply ExceededMaximumUptime=0 on
that group. This will disable ExceededMaximumUptime at a very fine level.
145
