DFM and SNMP
hey folks, I'm looking through the guide for DFM and I'm seeing things such as SNMPV3 Auth/Priv isnt supported only AuthNOPriv...Is there any way around this??? My SNMP config in CS is for SNMPV3 auth/priv...
thanks in advance
1 ACCEPTED SOLUTION
Re: DFM and SNMP
If you need to manage devices with DFM, you will need to use v3 authNoPriv for your SNMP credentials in DCR. Support for authPriv is coming in DFM 3.1.2 which should be out by next month.
Re: DFM and SNMP
Re: DFM and SNMP
thanks J...
bruce
Re: DFM and SNMP
hey J,
sorry, had one more question...you wouldnt happen to have a readme doc for 3.1.2 do you? or something I could reference that outlines the support for auth/priv
Re: DFM and SNMP
It has not been published yet. You'll find a hint of it if you search Cisco.com, but you will not be able to read it. It will be published when DFM 3.1.2 is released.
The following will be supported:
Auth: MD5, SHA
Priv: DES, AES128
All other privacy algorithms will not be supported.
Re: DFM and SNMP
thanks again...
123
