DFM device discovery
dionjiles
Is there a way to disable the built-in rediscovery for DFM.
Every week when the rediscovers network devices I lose device alerting capability and I have to reboot the server because DFM get hungs when
try to rediscover network devices.
There is a problem with the default schedule job in the databases.  You should be able to clean this up by opening a TAC service request.  There is a way to purge this job from the database, then create your own scheduled job which you can then suspend and resume as needed.
6 Replies 6
Joe Clarke
You cannot delete or edit the default schedule, but you can suspend it.  Just go to DFM > Configuration > Other Configurations > Rediscovery Schedule, and suspend the Default_Schedule option.
Thanks for the quick response......I get an error when I try to suspend rediscovery. "Cannot Suspend the discovery"
It tells me to check the rediscovery.log for details.
What errors are in the rediscovery.log?
Please see attached.
Thanks I will open a TAC Request in regards to this issue.
