Webcast-Catalyst9k
DFM - disable icmp polling - CSCsb48643
I just installed dfm 2.0.10 and would like to know where is the script that correct the bug CSCsb48643.
1 REPLY
Re: DFM - disable icmp polling - CSCsb48643
NMSROOT/objects/smarts/utils contains the scripts that will allow you to manage or unmanage IPs, interfaces, or devices in bulk.
130
