Attention: The Community will be in read-only mode on 12/14/2017 from 12:00 am pacific to 11:30 am.
During this time you will only be able to see content. Other interactions such as posting, replying to questions, or marking content as helpful will be disabled for few hours.
We apologize for the inconvenience while we perform important updates to the Community.
DFM ERROR
Hello sir,
We are using Ciscoworks lms 3.0 in our network .
Frequently, we are getting the following error through mail from DFM .
EVENT DESCRIPTION = HighQueueDropRate::Component=IF-ROUTER-1/13 [AT1/0/0];ComponentClass=Interface;ComponentEventCode=1053;Type=SONET;OutputPacketQueueDropPct=1.3081062 %;MaxSpeed=150000000;OutputPacketQueueDropRate=3.3625 PPS;OutputPacketNoErrorR
CUSTOMER IDENTIFICATION =
The polling and threshold setting are default in DFM manager.
Where we can find the parameters for this error.
What changes we have to make in order to avoid this problem.
Your help is highly appreciated,
Ashraf
Re: DFM ERROR
Go to DFM - Configuration - Polling and Thresholds- Managing Thresholds
Select your DFM - System Defined Groups and your specific interface category
Then modify the queue drop threshold
Re: DFM ERROR
Thanks a lot for your clarification. As u mentioned in your reply, i have done the same procedure and changed the queue drop threshold to 4% by default it is 1% still I am getting the same error message.
Note: we are getting these errors at peak hours when the users are not connected in network.
Please give an alternate solution to solve this problem.
OutputPacketQueueDropPct=2.4191074 %;MaxSpeed=150000000;OutputPacketQueueDropRate=1.8791667
kareem
Re: DFM ERROR
please help me for this issue
Re: DFM ERROR
any updates for dfm queuedrop thersold error
Re: DFM ERROR
please help me to avoid these errors.
Re: DFM ERROR
any updates
136
