Webcast-Catalyst9k
DFM HighDiscardRate
I'm receiving a lot of messages from DFM 3.0.3 about High Discard Rate on 2650 switches running 12.1.19.EA1 IOS or 12.1-22.EA11 IOS
Here below the message:
EVENT ID = 000032R
ALERT ID = 000015M
TIME = Thu 22-May-2008 13:07:38 CEST
STATUS = Active
SEVERITY = Critical
MANAGED OBJECT = EPE-C2950T-40
MANAGED OBJECT TYPE = Switches and Hubs
EVENT DESCRIPTION = HighDiscardRate::Component=PORT-EPE-C2950T-40/0.26 [Gi0/2] ["Lien 100TX vers C2950SX-30"];ComponentClass=Port;ComponentEventCode=1048;Type=ETHERNETCSMACD;OutputPacketDiscardRate=0.0 PPS;MaxSpeed=100000000;InputPacketRate=1.7896142E7 PPS;MinimumDisc
I checked and checked again on interface and there is no discard on interface.
Here below some indicators about interface :
EPE-C2950T-40#sh controllers ethernet-controller gi0/2
Transmit Receive
2753458867 Bytes 229595350 Bytes
165237242 Frames 2125895994 Frames
507279 Multicast frames 2 FCS errors
185977 Broadcast frames 2864901552 Multicast frames
0 Pause frames 268001458 Broadcast frames
0 Single defer frames 0 Control frames
0 Multiple defer frames 0 Pause frames
0 1 collision frames 0 Unknown opcode frames
0 2-15 collisions 0 Alignment errors
0 Late collisions 0 Length out of range
0 Excessive collisions 0 Symbol error frames
0 Total collisions 2 False carrier errors
0 Control frames 0 Valid frames, too small
0 VLAN discard frames 0 Valid frames, too large
0 Too old frames 0 Invalid frames, too small
160579422 Tagged frames 0 Invalid frames, too large
0 Aborted Tx frames 0 Discarded frames
Transmit and Receive
10362321 Minimum size frames
3229838505 65 to 127 byte frames
Any ideas?
Thanks in advance.
Re: DFM HighDiscardRate
The discard rate is clearly bogus (1.79x10^7 PPS). The device could be reporting bogus data via SNMP. It would help to see a sniffer trace covering two polling intervals of DFM to see exactly the data DFM is seeing.
Please find a sniffer trace (attachment)between LMS and switch at the time LMS sent a message.
Here below message from LMS:
EVENT ID = 00004WL
ALERT ID = 000017M
TIME = Tue 27-May-2008 22:07:38 CEST
STATUS = Active
SEVERITY = Critical
EVENT DESCRIPTION = HighDiscardRate::Component=PORT-EPE-C2950T-40/0.26 [Gi0/2] ["Lien 100TX vers C2950SX-30"];ComponentClass=Port;ComponentEventCode=1048;Type=ETHERNETCSMACD;OutputPacketDiscardRate=0.0 PPS;MaxSpeed=100000000;InputPacketRate=1.7821884E7 PPS;MinimumDisc
This decode is corrupt. Please post the binary sniffer file.
For security reason, I prefer to send you the decode directly. Is it possible?
You should open a TAC service request with this information then. That way you can have more privacy for your data.
292
