DFM install question
nawas
Level 4
Level 4
I'm running LMS3.2 but never installed DFM before, I ran LMS3.2 DVD and installed DFM today but after the intall It retured with the following error.
It asked me to choose a db password and I chose a password but of course it was not the password that I chose when I install LMS3.2. I don't even remember the old db password. Please advise.
Daemon Management 3.9 starting. Log=(syslog) /var/adm/CSCOpx/log/dmgtd.log
Finished:  Wed Oct 13 15:52:55 EDT 2010
===============- Software Installation Tool Completed -==============
===================- Possible Warnings/Errors Encountered -===================
WARNING: Ensure that you have installed the recommended Solaris 10 cluster patches released
WARNING: on  Apr/17/07, in this server.
WARNING: If these cluster patches are not installed, please download and install them
WARNING: from http://www.sun.com/.
WARNING: Otherwise, some features of the CiscoWorks applications will not function properly.
WARNING: Exiting installation beyond this point might result in system instability.
WARNING: Stale lock installed for pkgadd, pkg CSCOdfmdb quit in postinstall state.
ERROR: Failed to Start Database 'dfmInv' because: Could not connect to engine 'dfmInvEng' on 'dfmInvDb' in Bulk mode. Check user id and passwords
ERROR: Failed to connect to database 'dfmInv' with current password.
ERROR: Failed to update new userinfo into database.
ERROR: Failed to stop the database engine with old password: .
ERROR: Failed change password for database 'dfmInv'.
ERROR: Unable to Change password for DSN dfmInv
WARNING: Neither HP-OpenView or NetView is installed.
WARNING: To ensure that you have up-to-date device support,
WARNING: install the latest Service Pack (SP) from Cisco.com, at
WARNING: http://www.cisco.com/cgi-bin/tablebuild.pl/cw2000-dfm.
WARNING: Please refer to the Installation and Setup Guide for details.
Nael Mohammad
Level 5
Level 5
Run the following to reset your password for the databases and then try to run update again.
bash-3.00# ./perl dbpasswd.pl all
Usage:
Format1: dbpasswd.pl all
         Change all database passwords.
Format2: dbpasswd.pl listdsn
         List all available data sources in the product.
Format3: dbpasswd.pl dsn=odbc_datasource
         Change the database password.
Format4: dbpasswd.pl dsn=odbc_datasource npwd=new_password
         Change the database password to new_password.
Format5: dbpasswd.pl dsn=odbc_datasource encryption=yes
         Encrypt the database password.
Format6: dbpasswd.pl dsn=odbc_datasource encryption=yes npwd=new_password
         Change the database password and encrypt the database password.
I changed the password as sugested and re-ran the install but no luck.  it is
still not connecting.I have attached the install logs. Please advise.
1. Login as ROOT and stop the services.
2. Reinit the db and update the password using the steps below from CSCOpx/bin directory.
perl dbRestoreOrig.pl dsn=dfmInv dmprefix=INV npwd=cisco
perl dbRestoreOrig.pl dsn=dfmFh dmprefix=FH npwd=cisco perl dbRestoreOrig.pl dsn=dfmEpm dmprefix=EPM npwd=cisco
3.  Run installation, verify it completed, and let us know results. If that does not work, check your permissions on the /opt/CSCOpx directory, sub-directory, and ensure its "casuser:casusers" owned.
drwxrwxr-x  32 casuser  casusers      37 Oct 18 12:01 CSCOpx
Permission looks right to me, please see this. I'm doing the rest you asked and will report you shortly.
drwxrwxr-x  33 casuser  casusers      43 Oct 19 08:13 CSCOpx
