11-12-2008 04:48 AM
I have about 100 devices in my network and recently i added 4 more devices. but i saw that all the devices including the newly created went to learning state. and it get stuck at 90%. even a day has already passed but still the same.
11-12-2008 07:48 AM
This usually points to a daemon problem. Please post the output of the pdshow command. What version of DFM is this?
11-12-2008 10:09 AM
11-12-2008 11:00 AM
If you're really on DFM 2.0, you need to upgrade. LMS 2.5 is over three years old, and many bugs have been fixed in the newer versions. You are most likely seeing CSCsa50868 which is fixed in DFM 2.0.1. However, I recommend you move to LMS 2.6 which currently includes DFM 2.0.12. The updates to get you to LMS 2.6 can be freely downloaded from Cisco.com. You first need to go to LMS 2.5.1, then 2.6, then you can download the individual application service packs.
LMS 2.5.1 : http://www.cisco.com/cgi-bin/tablebuild.pl/lms25
LMS 2.6 : http://www.cisco.com/cgi-bin/tablebuild.pl/lms26
The individual service packs can be obtained from Common Services > Software Center > Software Update.
11-12-2008 11:07 AM
the bundle is LMS 2.6 already. Here is a table of installed modules.
Name Version Size Status Expiration Date
1. CM 4.0 300 Purchased Never
2. DFM 2.0 300 Purchased Never
3. IPM 2.6 300 Purchased Never
4. RME 4.0 300 Purchased Never
11-12-2008 11:09 AM
Then you're not running DFM 2.0. What is the exact version of DFM you are using?
11-12-2008 11:17 AM
the table with the versions is already provided but if it could be checked from anywhere else do let me know. regarding the bug id, it seems that after a 30 minute interval the devices move to known state. but it does not happen in this case even if a complete day has passed.
11-12-2008 11:18 AM
You can get the current version from Common Services > Software Center > Software Update. If you have LMS 2.6, then you cannot be seeing this bug. However, the fix solved quite a few of the 90% hangs. Others still existed, which is why this phase of the learning process was done away with in DFM 3.0.
11-12-2008 11:26 AM
DFM v2.0.6.
If this problem persists then can i upgrade the DFM module to 3.x.
11-12-2008 11:54 AM
Please post the DFMOGSServer.log, DFMOGSClient.log, and the NMSROOT/log/dfmLogs/TIS/TISServer.log.
11-12-2008 12:55 PM
11-12-2008 06:37 PM
It looks like there is a group problem. Try running the script NMSROOT/bin/perl NMSROOT/MDC/tomcat/webapps/triveni/WEB-INF/classes/rmkilnerogstable.pl. Then restart Daemon Manager. This should clear up the grouping issue.
11-13-2008 01:49 PM
still this has not resolved the issue.
11-13-2008 01:50 PM
Has the hostname of this server been changed recently?
11-13-2008 02:07 PM
no the hostname is same
