Webcast-Catalyst9k
dfm mail notification doesn't work
DFM (2.0.6) doesn't send smtp alerts.
And ..\CSCOpx\log\dfmLogs\NOS\nos.log is empty.
What all I may check? (mailhost is correct; Event Sets & Notification Groups etc also seems to be correct...)
Silver
Re: dfm mail notification doesn't work
There is an older DFM bug that makes that you need to reregister the NOS server.
I don't have the procedure with me unfortunately.
I'will try to look it up to night.
Cheers,
Michel
Silver
Hi Frank,
Is the NOS Server running? Check this by searching for "Common Services -> Server -> Admin -> Processes" the NOSServer process. Is it running?
With DFM 2.0.4 i had an issue with the NOSServer registration.
Navigate to "Common Services -> Server -> Admin -> Processes"
Click on the entry "NOSServer"
The following INformation should appear:
Process: NOSServer
Path: /opt/CSCOpx/bin/cwjava
Flags: -server -cp:a MDC/tomcat/webapps/triveni/WEB-INF/lib/ItemLogService.jar:
MDC/tomcat/webapps/triveni/WEB-INF/lib/log4j.jar:
MDC/tomcat/webapps/triveni/WEB-INF/lib/nos.jar:
MDC/tomcat/webapps/triveni/WEB-INF/lib/ctm.jar:
MDC/tomcat/webapps/triveni/WEB-INF/lib/ogs-client.jar:
MDC/tomcat/webapps/triveni/WEB-INF/lib/cogs.jar:
MDC/tomcat/webapps/triveni/WEB-INF/lib/activation.jar:
MDC/tomcat/webapps/triveni/WEB-INF/lib/mail.jar:
MDC/tomcat/webapps/triveni/WEB-INF/lib/tis-client.jar:
MDC/tomcat/webapps/triveni/WEB-INF/lib/pm.jar:
lib/classpath/jconn2.jar:lib/classpath/epm-v0-5-0.jar:
lib/classpath/cesar-v0-5-0b.jar:
MDC/tomcat/shared/lib/NATIVE.jar:
MDC/tomcat/shared/lib/MICE.jar:
MDC/bin:objects/nos/config:MDC/tomcat/webapps/triveni/WEB-INF/classes -cw:
jre /opt/CSCOpx/MDC/jre -Djava.compiler=NONE com.cisco.nm.trx.nos.server.NOSServer
Startup: Started automatically at boot.
Dependencies: EPMDbEngine EPMServer INVDbEngine PMServer DFMOGSServer
If there is a difference you might try tu unregister and register NOSServer.
Unregister:
/opt/CSCOpx/bin/pdreg -u NOSServer
Register:
/opt/CSCOpx/bin/pdreg -r NOSServer -d "EPMDbEngine EPMServer INVDbEngine PMServer DFMOGSServer" -e /opt/CSCOpx/bin/cwjava -f "^-server^-cp:a^MDC/tomcat/webapps/triveni/WEB-INF/lib/ItemLogService.jar:MDC/tomcat/webapps/triveni/WEB-INF/lib/log4j.jar:MDC/tomcat/webapps/triveni/WEB-INF/lib/nos.jar:MDC/tomcat/webapps/triveni/WEB-INF/lib/ctm.jar:MDC/tomcat/webapps/triveni/WEB-INF/lib/ogs-client.jar:MDC/tomcat/webapps/triveni/WEB-INF/lib/cogs.jar:MDC/tomcat/webapps/triveni/WEB-INF/lib/activation.jar:MDC/tomcat/webapps/triveni/WEB-INF/lib/mail.jar:MDC/tomcat/webapps/triveni/WEB-INF/lib/tis-client.jar:MDC/tomcat/webapps/triveni/WEB-INF/lib/pm.jar:lib/classpath/jconn2.jar:lib/classpath/epm-v0-5-0.jar:lib/classpath/cesar-v0-5-0b.jar:MDC/tomcat/shared/lib/NATIVE.jar:MDC/tomcat/shared/lib/MICE.jar:MDC/bin:objects/nos/config:MDC/tomcat/webapps/triveni/WEB-INF/classes^-cw:jre^/opt/CSCOpx/MDC/jre^-Djava.compiler=NONE com.cisco.nm.trx.nos.server.NOSServer"
(this all in one line!)
Hope that helps a bit. Ohterwise help us an provide a bit more details about your setup (Notification Groups and settings).
Best regards,
Frank
Silver
So here is the windows/dos version.
Cheers,
Michel
@ECHO OFF
SET NMSROOT=c:\CSCOpx
CALL %NMSROOT%\bin\pdreg.cmd -u NOSServer
CALL %NMSROOT%\bin\pdreg.cmd -r NOSServer -d "EPMDbEngine,EPMServer,INVDbEngine,PMServer,DFMOGSServer" -e %NMSROOT%\bin\cwjava.exe -f "^-server^-cp:p^MDC\tomcat\webapps\triveni\WEB-INF\lib\log4j.jar;MDC\tomcat\webapps\triveni\WEB-INF\lib\nos.jar;MDC\tomcat\webapps\triveni\WEB-INF\lib\ctm.jar;MDC\tomcat\webapps\triveni\WEB-INF\lib\ogs-client.jar;MDC\tomcat\webapps\triveni\WEB-INF\lib\cogs.jar;MDC\tomcat\webapps\triveni\WEB-INF\lib\ogs-kc1.0.jar;MDC\tomcat\webapps\triveni\WEB-INF\lib\ogs-kilnervirtualasa1.0.jar;MDC\tomcat\webapps\triveni\WEB-INF\lib\activation.jar;MDC\tomcat\webapps\triveni\WEB-INF\lib\mail.jar;MDC\tomcat\webapps\triveni\WEB-INF\lib\tis-client.jar;MDC\tomcat\webapps\triveni\WEB-INF\lib\pm.jar;lib\classpath\jconn2.jar;lib\classpath\epm-v0-5-0.jar;lib\classpath\cesar-v0-5-0b.jar;MDC\tomcat\shared\lib\NATIVE.jar;MDC\tomcat\shared\lib\MICE.jar;MDC\bin;objects\nos\config;MDC\tomcat\webapps\triveni\WEB-INF\classes;MDC\tomcat\webapps\triveni\WEB-INF\lib\ogs-util.jar;^-cw:jre^%NMSROOT%\MDC\jre^-cw:xrs^-Djava.compiler=NONE com.cisco.nm.trx.nos.server.NOSServer"
192
