Community Member
dfm not showing events
I have lms 2.5 and dfm 2.0 SP2.
When the server is running for a while, for example after 2-3 weeks, it stops showing the event details in an alert from the "Alerts and Activities" window.
I have checked that devices are managed successfully in DFM, alerts and events are available in fault history, but still the events are not available in the "Alerts and Activities" display.
A workaround is to delete the devices from DFM and then add them again, but this is not a solution for me.
Is this a bug?
Mladen
1 REPLY
Re: dfm not showing events
There were quite a few socket and thread leaks in your version of DFM. I recommend you upgrade to LMS 2.6 SP1 which will bring you to DFM 2.0.11. You should have better luck with keeping this version active.
101
