DFM - Power Supply Failed Detection on 4500s LMS 3.2
This device has two power supplies,  when one of them fails LMS (DFM) doesn't detect it.
What is the problem?
I attach some information.
Re: DFM - Power Supply Failed Detection on 4500s LMS 3.2
Hello, the problem is known with all Cisco IOS supervisor for the 450X and the 490X, i found the problem since the begin of the year, a tac request is open, the tac think a patch will generate for DFM in September.
Nicolas
go to the Detailed Device View for this device, then under Environment > Power Supply check if the managed status for both power supplies is "true";
from the output of your SNMP walk both power supplies are ok;
You can still add an Automatic Action on the syslog message generated when the power supply fails which e.g can send you an email;
166
