DFM - Power supply fault
good morning! I wish to do a foolowing question: is it possible display on alerts panel any trap received after a power supply fault? And, if yes, which configuration have I do?
Thanks in advance
Best regards
Alberto Malatesta
Re: DFM - Power supply fault
DFM is not a general purpose trap receiver, and will only process and/or display a small number of traps (none of which relates to power supply failures).
However, DFM will poll certain devices for PS failures. It just depends on your version of DFM, and the device in question. If DFM is able to detect a fault in a power supply, that fault will be displayed in DFM's Alerts and Activities Display.
I have a datacenter with 2 switch Catalyst 4507 e 2 router 7206VXR (to connecting via WAN small offices). The version of DFM is 2.0.6. Is DFM able to detect? I have made some tests but I haven't seen coming no message. In the case, can you suggest how have I configure DFM?
Thanks in advance
Best regards
140
