DFM: when does the "Alert ID" change for a device?
If an Event occures for device_A a corresponding Alert-ID x is generated. All Events for device_A are grouped together under this Alert-ID x.
Is there a corresponding time window in which all incomming Events for device_A will be grouped under this Alert-ID x or - if generated once this Alert-ID x is bound to device_A for eternity? (or just until the next restart of dmgtd?)
Does anybody know the sense behind these not rememberable Alert-IDs which are also useless for Notification Services?
The only thing I found was this:
Terminology has changed since DFM 1.2.x as follows:
•Symptom is replaced by event. Events are rolled up into alerts.
•Compound is not used and there is no replacement. A compound differs from an alert; there could be multiple compounds on a single device, whereas an alert is a roll-up of all events for a device.
from this Install Guide:
http://www.cisco.com/en/US/docs/net_mgmt/ciscoworks_device_fault_manager/2.0_IDU_2.0.6/installation_solaris/guide/newNav.html#wp1014226
  • Network Management
1 REPLY
Re: DFM: when does the "Alert ID" change for a device?
All events will be rolled into one alert as long as the alert stays active. Once the alert clears, and is moved to Fault History, then a new active event will create a new alert.
No, there is no significance to the Alert IDs. In fact, I typically recommend to customers not to do any notifications of alerts since events have all the juicy details.
114
