Community Member
DFMCTM
Process DFMCTM startup, data purge down.
Silver
Re: DFMCTM
Please post the output of pdshow. data purge is a periodic process that does not run all the time.
Re: DFMCTM
This is normal. These processes can be down in normal operation. DataPurge is only started as needed, and DFMCTMStartup may not be used at all if another daemon is doing its job.
167
