DFMCTMStartup, RmeGatekeeper and DataPurge down
In the Common Services there are three services down.
Are, DFMCTMStartup, RmeGatekeeper, DataPurge they are write in red color on the CiscoWorks screen.
I have LMS 3.0.1 (modules versions CM 5.0, DFM 3.0, IPM 4.0, RME 4.1 and CS 3.1.1)
Do you have any idea from where the problem is coming from ?
Thanks in advance for your help,
best regards!
1 ACCEPTED SOLUTION
Re: DFMCTMStartup, RmeGatekeeper and DataPurge down
No, this is not possible. Gatekeeper must be able to use this port.
DFMCTMStartup and DataPurge are typically down in normal operation. RmeGatekeeper is a problem. This typically occurs if the IP address of the machine was changed, or if certain TCP ports are already in use on the system. Post the output of netstat -a -n -o -b, and the NMSROOT/lib/vbroker/gatekeeper.cfg.
Hi JClarke!
I attach the files.
Thanks very much!
best regards,
Jorgelina
The process FrameworkService.exe is occupying tcp/9091. You need to stop this service, or configure it to use a different port. After doing that, restart Daemon Manager, and you should be set.
Ahh ok, I understand.
And.. Exist any way to change or configure the port of the rmegatekeeper in other port number?
Thanks !
Hi Jclarke!
The program who use this port is an antivirus (McAfee) . And for corporate reason we do not able to remove.
I think will try with other brand of antivirus.
Or move all CWLMS to Solaris platform.
Have a nice weekend!
best regards,
Jorgelina
1051
