Community Member
DHCP address logging
Hello, I have a 2651 router that is configured to run DHCP. I am trying to determine if there is a way to log DHCP leased addresses and export those logs to a syslog server. I currently have a syslog server set up but do not see any entries for DHPC address assignments. I also do not see any commands to display currently leased addresses. Any assistance is appreciated.
Community Member
Re: DHCP address logging
It's possible to configure through SNMP. use the following method for this,
1) first enable the SNMP traps for syslgs
eg:- snmp-server eneble traps syslog
2) Enable syslog for logging traps with severity level 6
Community Member
I have configured SNMP and traps logging as you have suggested. I connected a client and received an IP address. As of yet I have not seen the event logged to my syslog file. I'll give it some time and try again later. Thanks for your help.
223
