DHCP and Bridge
I meet a mistake with a cisco SOHO 97 and IOS 12.4.
I have a server DHCP on the router. When I bridge eth0 and ATM0 my server can not give address anywhore.
Can someone help me ?
Re: DHCP and Bridge
When you use bridiging like this, the router probably assigns dhcp on the ATM as well. When this is an Internet connection your ISP will be quite unhappy as you are assigning your adresses to his other customers.
At your end, the ip pool will be exhausted rather quickly which might explain why it does not work for your server. To make a long story short: do not try this at home!
Please post your config if this does not apply.
Leo
Re: DHCP and Bridge
Tahnks for your answer.
Here my config
version 12.4
no service pad
service password-encryption
hostname MyHostname
boot-start-marker
boot system flash soho97-k9oy1-mz.124-10a.bin
boot-end-marker
enable secret 5 MySecret
enable password 7 MyPassword
no aaa new-model
no ip routing
no ip dhcp use vrf connected
ip dhcp excluded-address 172.18.15.200 172.18.15.254
ip dhcp pool Client
network 172.18.15.0 255.255.255.0
default-router 172.18.15.254
dns-server 172.18.4.11 172.18.4.12
domain-name Mydomain.com
lease 42
no ip cef
interface Ethernet0
ip address 10.2.15.254 255.255.255.0 secondary
ip address 172.18.15.253 255.255.255.0
no ip route-cache
no ip mroute-cache
bridge-group 1
hold-queue 100 out
interface ATM0
no ip address
no ip route-cache
no ip mroute-cache
no shutdown
no atm ilmi-keepalive
dsl operating-mode auto
bridge-group 1
pvc 8/35
pppoe-client dial-pool-number 1
no ip http server
no ip http secure-server
dialer-list 1 protocol ip permit
control-plane
bridge 1 protocol dec
line con 0
no modem enable
stopbits 1
line aux 0
stopbits 1
line vty 0 4
password 7 MyVirtualPAssword
login
scheduler max-task-time 5000
end
Julien
Re: DHCP and Bridge
Hello Julien,
I'm sorry that it took a while to get back on this one but I happen to have missed your reply.
What do you intend to realize with this config? If it is intended for internet access I am missing the nat statements. Also noticed you are using PPPoE so please check the URL below for a few configuration examples.
http://www.cisco.com/en/US/products/sw/iosswrel/ps1834/products_feature_guide09186a00800800f4.html
Leo
287
