DHCP
A couple of the computer's on the network are having a hard time with the DHCP. I use a PPPoE, and I was wondering If I was to disable the DHCP how this would effect other computers on the network, wireless and hard wired. Also once I disable the DHCP how to make everything on the Network if it is possible.
1 REPLY
Anonymous
N/A
Re: DHCP
Is there any pix installed between the DHCP server and the clients?
verify whether you need a manual binding for the pc or mac address on the dhcp server
93
