Community Member
Diferences between Dynamic groups rules in Prime 2.1 and LMS 4.2
I am performing a migration from LMS to Prime 2.1 and I am having some troubles in my dynamic groups.
In LMS there is a lot of parameters and rules, like Domain name or just nume. On the other hand, in Prime 2.1 there are just a few. As you can see in two attached JPG, rules are quite different.
When I am importing devices in Prime 2.1 from LMS, devices are not added dynamically in my groups because I can't define Domain name as a rule.
Any suggestion?
David
Everyone's tags (4)
1 ACCEPTED SOLUTION
Highlighted
Unfortunately LMS and CPI
Unfortunately LMS and CPI doesn't have a exact feature parity and many very common and important features are missing in CPI.
You have to manage it with the options available in the CPI for your Dynamic groups. Domain name is unfortunately not an option in CPI.
-Thanks
Vinod
-Thanks Vinod **Rating Encourages contributors, and its really free. **
1 REPLY
Highlighted
-Thanks
Vinod
65
