Webcast-Catalyst9k
Differences/Benefits of LMS, Cisco Performance, ANA
We need to know de differences/benefits between:
-Cisco Prime Lan Management Solution (LMS)
-Cisco Prime Performance Management
-Cisco Active Network Abstraction (ANA)
Hall of Fame Super Silver
LMS - an enterprise network management system that does fault, configuration and performance functions for a diverse set of Cisco equipment. Data Sheet and Supported Devices.
Performance Management - a primarily service provider-oriented product focused on a few carrer-class devices (reference Table 2 of the Product Data Sheet and the Supported Devices Table).
ANA - a product also designed to manage carrier networks. Recast as "Cisco Prime Network".
I need only an application for:
  • View topology
  • Inventory
  • Monitoring
  • Change administration
  • Configuration backup
Which one of them can offer all of it?
What equipment is in your network? If it is all Cisco (and included in the Supported devices link I posted above) then LMS will do all of those functions.
Keep in mind that you will need your structure operations procedures around the capablities of the tool.
329
