disable SNMP trap on subinterfaces
ariesc_33
Hi all,
I want to disable receiving SNMP trap status from subinterfaces but still will receive trap from physical interface st. Already entered the command "no snmp trap link-status" but still DFM keep receiving traps. See my configuration below. Any suggestion?
interface GigabitEthernet0/0.1204
description *****for testing*****
encapsulation dot1Q 1204
ip unnumbered Loopback1001
ip helper-address ******
interface GigabitEthernet0/0.1800
encapsulation dot1Q 1800
9 Replies 9
muttman15
I would try adding this line
"no logging event link-status "
This was an issue that was hammering our syslog server and adding both your line above and this line seemed to do the trick
Joe Clarke
What version of IOS is this device running? Are you certain it is traps you are receiving, and not syslog messages? Please provide an example trap.
it is the interface status alarms...
ios version
(C7301-SPSERVICESK9-M), Version 12.4(6)T2
Event_Description OperationallyDown
Component IF-10.*.*.*/1902 [Gi0/2.3535]
Type L2VLAN
OperStatus DOWN
InterfaceCode CODEUNKNOWN
DuplexMode FULLDUPLEX
AdminStatus UP
LastChangedAt 16-Mar-2007 12:26:22
IsFlapping false
MaxSpeed 1000000000
Mode NORMAL
is DFM able to receive syslogs? Thanks
No DFM does not handle syslog messages, the only thing is that DFM can be configured to generate syslog messages for a specific event and forward it to a syslog receiver ( e.g RME);
Aries,
look at line 1,4,7 and 8 of the event:
'Event_Description OperationallyDown '
'OperStatus DOWN '
'AdminStatus UP '
'LastChangedAt 16-Mar-2007 12:26:22'
this indicates, that it is not an event caused by a received trap, but generated based on the responses from the device to an active poll from DFM;
Enabled by default, DFM polls the gig interface if its 'ifAdminStatus' is set to 'UP';
but as its 'ifOperStatus' indicates 'DOWN', DFM assumes this is a fault;
DFM interface rules are based on the assumtion that all interfaces which are administratively up should also forward traffic (operational up);
You have 2 Options:
in DFM set the managed state of this interface to false;
on the device,configure the 'shutdown' command on the interface;
Would it be possible to poll only the physical interface [gig 0/1] and not the subinterface [gig 0/1.222]?
open the detailed device view for the device:
DFM > Device Management > View Device Details
select the device, go to Interface Status - Interfaces
there you should see all interfaces and you can change the managed state for each
after all changes, apply the changes by selecting
Configuration > Polling and Threshold > Apply Changes
it takes about 30 minutes to open interface status probably because routers has around 4000 subinterface.
Only solution i can see right now is to disable polling from lms to router and enable on the router the manual trap sending..?
Any other suggestion?
what happens if you 'shutdown' the subinterace on the router?
with this command the SNMP ifAdminStatus is set to down and it shouldn't be an issue for DFM anymore.
I don?t know of a cli command to disable a bunch of (sub-)interfaces in DFM to workaround the GUI
Other possibility could be to generate an action (e.g. email) based on syslog for the physical if..
