10-06-2005 06:31 AM
When I do a discovery wtih CM it puts the loopback address into the device name. Is there any way to make it put the hostname into the device name catagory?
10-06-2005 08:18 AM
That can be changed in the ANIServer.properties file.
nameserver.useloopbackaddress=true
this could also be set to false.
On unix it's:
johnsonr@nmsccm01 > pwd
/opt/CSCOpx/campus/etc/cwsi
johnsonr@nmsccm01 > ls ANIServer.properties
johnsonr@nmsccm01 >
10-06-2005 10:20 AM
There isn't any line
I'm trying to make it use the hostname when there isn't any dns.
10-07-2005 02:36 AM
What version are you using?
In 2.5 you can define this via:
Campus Manager Admin>Device Discovery>Discovery Settings>Use Loopback Address.
Although i've not had much luck, even using this. I had to delete the device from the database, then delete the loopback address from the DNS, then add the device again in LMS via the node name.
Keith
10-13-2005 12:00 PM
It is currently using the loopback address for the hostname. I want it to display the hostname on the router as the hostname in ciscoworks. Reading a list of loopback addresses isn't as easy as a list of hostnames.
10-13-2005 11:18 PM
Does the DNS server your LMS box is using have entries for the loopback addresses?
10-18-2005 05:21 AM
There is no DNS box for the network. I simply want it to pull the hostname that is written in the router config and use it in place of the loopback address.
