Discovering devices on GRE tunnels
wwanjohi123
Am not able to discover devices on GRE tunnels because from my seed device, they are not CDP neighbours and i have configured CDP RUN on the seed device. The tunnel addresses of these devices are only seen as IP EIGRP NEIGHBOURS. Is there any other way discovering them from campus manager. Kindly assist.
to manually add devices as a seed device just go to
CampusManager > Administration > Device Discovery > Discovery Settings > Seed Device(s) =>Configure then 'Add'
Enter the IP Address from the devices that cannot be discovered. Enter an IP that the management server can reach (if the device has multiple addresses)
Joe Clarke
If you upgrade to LMS 3.0.1 you will get the ability to do a variety of non-CDP based discoveries. Prior to that, you will have to manually add seed devices on each side of the tunnel.
How do i maually add seed devices on each side of the tunnel, do you mean a configuration on both of the end devices where the tunnels terminate?
If so what are the configurations?
