Webcast-Catalyst9k
discovery of 1721 connected to 6509 directly
I am using lms 2.5.1 and trying to discover all devices connected to a 6509.
All the switches are discovered with all details, but the 1721 router (IOS ver 12.2(8)T4) which is directly connected to the 6509 is not discovered at all.
I have enabled cdp globaly on the router and added it to seed devices in Campus Manager discovery, but the device shows unknown in the discovery report.
All help is appreciated.
Silver
Re: discovery of 1721 connected to 6509 directly
If the 1721 router is in the CDP table (sho cdp neig) of the 6509 and the 6509 is in the CDP table of the 1721 router and both devices are SNMP manageble for ciscoworks then the router will be discovered.
Cheers,
Michel
Thanks for the reply...
The problem was some security settings on the Vlan where the LMS server was. This prevented it from contacting any wan elements. Everything is fine now.
Thanks again
119
