discrepancy of RME and DCR databases
At this moment we have 3 CiscoWorks servers in 3 data centers
10.228.106.251 (runs the master DCR)
10.230.105.251 (runs a slave DCR)
10.232.104.251 (runs a slave DCR)
A Peer server User and password are setup on all servers
A System Identity User and password are setup on all servers
Self-signed certificates are created on all 3 servers and the Master certifcate is copied to the slaves and the Slave certificates to the Master.
Those are valid
In the DCR on the master there are 682 devices (when I select 'All Devices')
In the RME on the master I see
RME/Devices/Device Mgmt: 715 devices
RME/Config/Archive Mgmt: 715 devices
In the RME on the slave 10.230.105.251 I see
RME/Devices/Device Mgmt: 673 devices
RME/Config/Archive Mgmt: 366 devices
In the RME on the slave 10.232.104.251 I see
RME/Devices/Device Mgmt: 702 devices
RME/Config/Archive Mgmt: 390 devices
My question :
How is it possible that the RME slaves have such a different number of devices?
All suggestions/explanations are welcome ...
Thx,
Jan
1 REPLY
Re: discrepancy of RME and DCR databases
Assuming the servers are not integrated with ACS, or they are integrated with ACS, and you are using the same user on all servers, the most likely causes of the discrepancy are one, that RME auto-manage is disabled on the servers, and you have manually managed different devices in each server, or two, the servers all have different Common Services MDF versions. If the MDF is different on the master vs. the slaves, then some devices might not sync correctly between the master and slave.
Check Common Services > Software Center > Device Update > CiscoWorks Common Services to make sure the MDF version is the same on all servers.
111
