09-28-2009 10:55 AM
I'm getting the following error on my LMS 3.0 Master system. This is a Unic system running on Solaris 10.
I've removed some log files from /var/adm/CSCOpx/log but none of them were very large. I opened the diskWatcher.log file and noticed it was pointing to /opt/CSCOpx/databases. There are some large files under the subfolders in the above directory. /rmeng in particular has SyslogFirst.db, SyslogSecond.db and SyslogThird.db. All of which are well over a Gig in size.
Do you have any recommendations on how to clean up the /var partition?
09-28-2009 11:12 AM
You will need to contact TAC to get the DBSpaceReclaimer.class tool. This tool can then safely drop the syslog data spaces, freeing up the disk space.
09-28-2009 11:24 AM
Will do. Thanks for the quick response...
