Do SNMP agents and servers(LMS 2.5) have to be in the same subnet?
Hi mates :)
I have an SNMP enabled switch and a Network management server with LMS 2.5 installed.
My question: Do server's IP address and switch's IP address have to be in the same subnet in order to send/recieve SNMP traps and use other SNMP features properly?
My switch's IP address (IP address of Interface VLAN 1)is 10.10.10.1/8
Would SNMP works if I assign 192.168.1.1/24 to Server (LMS 2.5 installed)
(LMS 2.5 Server is directly connected to the switch)
For some reason I need my switch's IP address in a different subnet then and LMS 2.5 Server
Thanks for helping :)
1 ACCEPTED SOLUTION
Silver
Re: Do SNMP agents and servers(LMS 2.5) have to be in the same s
As long as there is a router to interconnect these subnets (10.10.10.x and 192.x.x.x) that allows the SNMP traffic then this should work.
SNMP, syslog and other traffic normaly passes unless filtered.
cheers,
Michel
Silver
cheers,
Michel
thanks Michel :)
105
