Does HUM 1.2 support formulas?
I wanted to know if it's possible to define formulas in HUM 1.2 in order to divide the result of some SNMP queries, etc.
Many thanks.
1 ACCEPTED SOLUTION
Re: Does HUM 1.2 support formulas?
Not really. There is a new feature called Trendwatch which allows you to define some formulaic analysis of threshold trends, but nothing that allows you to, say, calculate percent of used DS0s.
1 REPLY
120
