duplicate IP's in RME
I have some 700 devices in my network, 140 of them routers with multiple interfaces. I want to use LMS 2.6 to keep track of inventory. When I run a report and compare it to the paper inventory I currently have I find that CW is reporting a device sometimes 3 times using different interfaces.
what's the deal???
thanks
tony
1 REPLY
Re: duplicate IP's in RME
Check RME > Devices > Device Management > Alias Devices to see if you have entries there. If you do, resolve the aliases, and this problem should go away.
94
