Community Member
DXX issue
any one help me about this matter.
I have DXX link b/w my two node. one is Head office and one is Branch.
when I use show int serial1/0 I have receive
Serial is up and line Protocol is up at both end and data transfer is also fine no problem.
But DSR which i highlighted is showing Down. What is this problem?
I can't understand any one define me.
RouterXYZ>show int se4/4
Serial4/4 is up, line protocol is up
Hardware is CD2430 in sync mode
Description: - 64k DXX Link......
Internet address is 10.X.X.X/30
MTU 1500 bytes, BW 64 Kbit, DLY 20000 usec,
reliability 255/255, txload 3/255, rxload 3/255
Encapsulation HDLC, loopback not set
Keepalive set (10 sec)
Scramble enabled
Last input 00: 00:00 , output 00:00:00, output hang never
Last clearing of "show interface" counters 2w6d
Input queue: 0/75/0/0 (size/max/drops/ flushes); Total outp
Queueing strategy: weighted fair
Output queue: 0/1000/64/4 (size/max total/threshold/ drops)
Conversations 0/29/32 (active/max active/max total)
Reserved Conversations 0/0 (allocated/max allocated)
Available Bandwidth 48 kilobits/sec
5 minute input rate 1000 bits/sec, 2 packets/sec
5 minute output rate 1000 bits/sec, 1 packets/sec
2989857 packets input, 259973705 bytes, 0 no buffer
Received 210049 broadcasts, 0 runts, 1 giants, 0 thrott
164 input errors, 58 CRC, 0 frame, 0 overrun, 0 ignored
2645960 packets output, 393415097 bytes, 0 underruns
0 output errors, 0 collisions, 198 interface resets
0 carrier transitions
DCD=up DSR=down DTR=up RTS=up CTS=up
165
