04-23-2008 06:54 AM
From time to time, DFM stops sending e-mail notifications. I have to stop and start CiscoWorks daemon manager to resolve the problem. Does anybody know what is causing the problem and how to resolve it? Are there any particular processes I can restart instead of restarting CiscoWorks daemon manager? Thank you.
Solved! Go to Solution.
04-23-2008 08:34 AM
This could be my bug, CSCso28593:
Symptom:
Device Fault Manager does not send any notifications even though new alerts and events are properly being displayed in the Alerts and Activities Display
Conditions:
This occurs in DFM 2.0 after upgrading to DFM 2.0.10 as well as in all versions of DFM 3.0.
Workaround:
There is no workaround.
A patch is available by calling the TAC.
04-23-2008 08:34 AM
Symptom:
Conditions:
Workaround:
04-23-2008 09:02 AM
I opened a case with TAC. Thank you!
