Community Member
editing device credential on more than one device at a time
Hi Guys,
I need to change the password Ciscoworks uses in accessing my devices(common services). I know how to do this one at a time but i need to edit them all at once.
any ideas.
Silver
Re: editing device credential on more than one device at a time
The method I've found to be the easiest is to do a full inventory export to csv and do a find/replace on the password field using your favorite utility (vi, excel, etc) and then re-import using the file as the autoritative source so that the changes are propagated to your live inventory. I do this about once a quarter for SOX compliance.
Silver
Hi Akinsola,
i am used to t this:
navigate to "Common Services -> Device and Credentials -> Device Management" and check the entry "Device Type Groups" for all devices and click on the button "Edit Credentials".
Change the values you want and click on "Finish".
I hope that helps.
Best regards,
Frank
119
