Webcast-Catalyst9k
EEM and IP SLA
switch1 (4506, IOS 12.2(53)SG1)
switch1 has default gateway 1.1.1.1 (telco), if 1.1.1.1 is not reachable by PING, then switch1 need remove the default gateway and install a new default gateway of 2.2.2.2, if ping is working, then switch1 need remove 2.2.2.2 and add 1.1.1.1 as default gateway
is this doable with EEM and IP SLA?
thanks
Re: EEM and IP SLA
Yes, this is doable provided 1.1.1.1 is not reachable when 2.2.2.2 is the default gateway.  If that is the case, then post the output of "show event manager detector all".
Re: EEM and IP SLA
Thanks for your reply, I am not new to IOS, but new to EEM, if you could, please help to provide a small script for the case
No.  Name                Version   Node        Type
1    appl                01.00     node1/0     RP
2    syslog              01.00     node1/0     RP
3    rf                  01.00     node1/0     RP
4    energywise          01.00     node1/0     RP
5    cli                 01.00     node1/0     RP
6    config              01.00     node1/0     RP
7    counter             01.00     node1/0     RP
8    env                 01.00     node1/0     RP
9    gold                01.00     node1/0     RP
10   interface           01.00     node1/0     RP
11   ioswdsysmon         01.00     node1/0     RP
12   none                01.00     node1/0     RP
13   oir                 01.00     node1/0     RP
14   snmp                01.00     node1/0     RP
15   snmp-notification   01.00     node1/0     RP
16   test                01.00     node1/0     RP
17   timer               01.00     node1/0     RP
18   rpc                 01.00     node1/0     RP
Embedded Event Manager Version 2.40
Component Versions:
eem: (v240_throttle)2.21.112
eem-gold: (v240_throttle)1.2.37
eem-call-home: (v240_throttle)2.0.1
Event Detectors:
rf                  01.00     node1/0     RP
Re: EEM and IP SLA
You do not have the track ED (which is what I thought would be the case).  However, you should be able to use object tracking combined with syslog to get what you need.  Make sure your IP SLA collector is being tracked with enhanced object tracking.  For example:
track 1 ip sla 1 reachability
Then, you can use these EEM applets to accomplish what you need:
event manager applet track-down
event syslog pattern "TRACKING-5-STATE: NUM .*Up->Down"
action 1.0 cli command "enable"
action 2.0 cli command "config t"
action 3.0 cli command "no ip route 0.0.0.0 0.0.0.0 1.1.1.1"
action 4.0 cli command "ip route 0.0.0.0 0.0.0.0 2.2.2.2"
action 5.0 cli command "end"
event manager applet track-up
event syslog pattern "TRACKING-5-STATE: NUM .*Down->Up"
action 3.0 cli command "no ip route 0.0.0.0 0.0.0.0 2.2.2.2"
action 4.0 cli command "ip route 0.0.0.0 0.0.0.0 1.1.1.1"
Here, NUM refers to the track number (e.g. that would be 1 in my example above).
601
