EEM applet does not support extended ping ?
Hi does anybody know if EEM applet does not support any extended Ping in a cli action ?
This works:
action 1000 cli command "ping ip 10.161.255.5"
These statements does not work ?
action 1000 cli command "ping ip 10.161.255.5 repeat 10 source Loopback0"
action 1000 cli command "ping vrf TESTVRF ip 10.161.255.5 repeat 20 source Loopback0"
I  found another possibility how to achive extended ping in EEM like following
event manager applet ping
event none sync yes
action 100 cli command "enable"
action 101 cli command "ping" pattern "[ip]"
action 102 cli command "ip" pattern "address"
action 103 cli command "10.161.255.5" pattern "count"
action 104 cli command "20" pattern "size"
action 105 cli command "100" pattern "seconds"
action 106 cli command "2" pattern "commands"
action 107 cli command "y" pattern "interface"
action 108 cli command "Loopback0" pattern "service"
action 109 cli command "0" pattern "header"
action 110 cli command "no" pattern "data"
action 111 cli command "no" pattern "pattern"
action 112 cli command "0xABCD" pattern "Verbose"
action 113 cli command " " pattern "size"
action 114 cli command "n" event manager applet ping
bu there is also no way to specify the VRF ?
Any Ideas ?
Thx
Hubert
1 REPLY
Hi found failure,
extended ping needs to be executed in priviledged mode, so need to enable in advance , then it works
thx Bruno for the hint
Hubert
447
