07-09-2012 08:44 AM
I am trying to generate an EEM script that will send some message to all terminal lines, but I am having the next problem: I cannot get the script to use the action "send *" and to write something in the box, then to simulate the CTRL+Z keywords in order to confirm + exit.
Could someone please help me out ?
Thanks !
07-09-2012 12:08 PM
I think this thread will help you out.
07-10-2012 01:08 AM
Hey Joseph,
I am not familliar with TCL scripting so I was just trying to make a small applet, I see the guys there are using TCL scripts for this...
You think that what I am trying to make is not possible using applets ?
Thanks !
07-10-2012 09:33 AM
No, an applet will not work here as you won't be able to generate the ^Z character.
