Attention: The Community will be in read-only mode on 12/14/2017 from 12:00 am pacific to 11:30 am.
During this time you will only be able to see content. Other interactions such as posting, replying to questions, or marking content as helpful will be disabled for few hours.
We apologize for the inconvenience while we perform important updates to the Community.
Embedded CiscoView + Cat4500
I am following the instructions to load Embedded CiscoView into my Supervisor II+ and can't get the tar'd files into the right directory.
The instructions say that if the "cv" directory doesn't exist, which it doesn't to run this command
archive tar /xtract tftp://<tftp server>/Cat4000IOS.v12-0.tar slot0:
That works fine, except that from the documentation on CiscoView, the HTML needs to be in the "cv" directory.
How can I get it to work properly, or how can I create a "cv" directory so that I can untar the files to the right place?
1 REPLY
Silver
Re: Embedded CiscoView + Cat4500
check out the following link for installing embedded ciscoview on Catalyst 4500 switches :
http://www.cisco.com/en/US/products/hw/switches/ps4324/products_configuration_guide_chapter09186a0080379a56.html#wp1075254
175
