Community Member
enable rdp, ftp and telnet to cisco ASA 5505
Hello, can someone tell me what the command string are for enabling FTP and RDP thru the firewall to a server with an address of 192.168.1.x?
Also, how do I enable telnet to the 5505 from outside?
1 REPLY
Community Member
Re: enable rdp, ftp and telnet to cisco ASA 5505
I'm assuming that you are trying to access a server that is behind the firewall. To do this, you will need to create a static mapping:
static (inside, outside) external.ip 192.168.1.x netmask 255.255.255.255
and assign an access list to the outside interface that allows access to the required ports.
You cannot telnet to an ASA outside interface without a VPN. Use SSH
1621
