Enable snmp traps on Nexus1000V
Hello community,
I have the following issue. I want to configure snmp-traps regarding stpx (root-inconsistency, loop-inconsistency) on a Cisco Nexus 1000V.
The command "show snmp traps" lists stpx as a trap that could be configured and which is not at the moment.
MKBE1NX1# sh snmp trap
Trap type                                           Enabled
entity               : entity_mib_change               Yes
entity               : entity_module_status_change     Yes
entity               : entity_power_status_change      Yes
entity               : entity_module_inserted          Yes
entity               : entity_module_removed           Yes
entity               : entity_unrecognised_module      Yes
entity               : entity_fan_status_change        Yes
entity               : entity_power_out_change         Yes
link                 : linkDown                        Yes
link                 : linkUp                          Yes
link                 : extended-linkDown               Yes
link                 : extended-linkUp                 Yes
link                 : cieLinkDown                     No
link                 : cieLinkUp                       No
link                 : connUnitPortStatusChange        Yes
rf                   : redundancy_framework            Yes
aaa                  : server-state-change             No
license              : notify-license-expiry           Yes
license              : notify-no-license-for-feature   Yes
license              : notify-licensefile-missing      Yes
license              : notify-license-expiry-warning   Yes
zone                 : unsupp-mem                      No
upgrade              : UpgradeOpNotifyOnCompletion     No
upgrade              : UpgradeJobStatusNotify          No
feature-control      : FeatureOpStatusChange           No
rmon                 : risingAlarm                     No
rmon                 : fallingAlarm                    No
rmon                 : hcRisingAlarm                   No
rmon                 : hcFallingAlarm                  No
config               : ccmCLIRunningConfigChanged      No
snmp                 : authentication                  No
bridge               : topologychange                  No
bridge               : newroot                         No
stp                  : inconsistency                   No
stpx                 : loop-inconsistency              No
stpx                 : root-inconsistency              No
The only snmp traps that can be configured on the system are:
aaa              Module notifications enable
  config           Module notifications enable
  entity           Module notifications enable
  feature-control  Module notifications enable
  license          Module notifications enable
  link             Module notifications enable
  rf               Module notifications enable
  rmon             Module notifications enable
  snmp             Module notifications enable
  upgrade          Module notifications enable
  zone             Module notifications enable
Nothing about stpx... Is there some other way to configure more traps?
Thanks in advance,
Katerina
Joel Monge
Looks like you could be hitting CSCsz96130 "show snmp trap displays five unconfigurable types bridge / stpx" and it looks like support has been added starting 5.0(2)N1(1).
Joel Monge
Joel
thank you for your answer!
