12-19-2011 02:06 AM
Hello community,
I have the following issue. I want to configure snmp-traps regarding stpx (root-inconsistency, loop-inconsistency) on a Cisco Nexus 1000V.
The command "show snmp traps" lists stpx as a trap that could be configured and which is not at the moment.
MKBE1NX1# sh snmp trap
Trap type Enabled
entity : entity_mib_change Yes
entity : entity_module_status_change Yes
entity : entity_power_status_change Yes
entity : entity_module_inserted Yes
entity : entity_module_removed Yes
entity : entity_unrecognised_module Yes
entity : entity_fan_status_change Yes
entity : entity_power_out_change Yes
link : linkDown Yes
link : linkUp Yes
link : extended-linkDown Yes
link : extended-linkUp Yes
link : cieLinkDown No
link : cieLinkUp No
link : connUnitPortStatusChange Yes
rf : redundancy_framework Yes
aaa : server-state-change No
license : notify-license-expiry Yes
license : notify-no-license-for-feature Yes
license : notify-licensefile-missing Yes
license : notify-license-expiry-warning Yes
zone : unsupp-mem No
upgrade : UpgradeOpNotifyOnCompletion No
upgrade : UpgradeJobStatusNotify No
feature-control : FeatureOpStatusChange No
rmon : risingAlarm No
rmon : fallingAlarm No
rmon : hcRisingAlarm No
rmon : hcFallingAlarm No
config : ccmCLIRunningConfigChanged No
snmp : authentication No
bridge : topologychange No
bridge : newroot No
stp : inconsistency No
stpx : loop-inconsistency No
stpx : root-inconsistency No
The only snmp traps that can be configured on the system are:
aaa Module notifications enable
config Module notifications enable
entity Module notifications enable
feature-control Module notifications enable
license Module notifications enable
link Module notifications enable
rf Module notifications enable
rmon Module notifications enable
snmp Module notifications enable
upgrade Module notifications enable
zone Module notifications enable
Nothing about stpx... Is there some other way to configure more traps?
Thanks in advance,
Katerina
Solved! Go to Solution.
12-19-2011 08:01 AM
Looks like you could be hitting CSCsz96130 "show snmp trap displays five unconfigurable types bridge / stpx" and it looks like support has been added starting 5.0(2)N1(1).
12-19-2011 08:01 AM
12-19-2011 11:37 PM
Joel
thank you for your answer!
