Enabling Shadow Directory for Archive Management in RME
Hello:
I'm trying to enable shadow directory in RME > Admin > Config Mgmt > Archive Mgmt > Archive Settings. When I click apply, I get the following error:
Could not save new settings.
Cause: "ConfigMgmtServer" service is running.
Action: Stop "ConfigMgmtServer" service before applying the settings.
The problem is I don't show to stop this service. It's not under Windows Services and if I stop the CW daemon, I can't log into the web interface to checnge this function.
How do I go about doing this?
I'm running LMS 2.5.1, RME 4.0.4 on a Win 2003 server.
1 ACCEPTED SOLUTION
Re: Enabling Shadow Directory for Archive Management in RME
Perhaps this will help:
Stop the ConfigMgmtServer process. To do this follow this procedure:
Select Common Services > Server > Admin > Processes.
The Process Management dialog box appears.
Select the ConfigMgmtServer process.
Click Stop.
Select Resource Manager Essentials > Admin > Config Mgmt > Archive Mgmt.
The Archive Settings dialog box appears.
Select the Enable Shadow Directory check box.
Click Apply.
A message shows that the changes were made.
Restart the ConfigMgmtServer process. To do this follow this procedure:
Click Start.
1 REPLY
Click Stop.
Click Apply.
Click Start.
260
