Entering carriage returns in Netconfig.
Does anyone know of a way to enter carriage returns within user defined tasks in NetConfig?
If this is not possible, has anyone tried this before and found a workaround?
i am trying to save the startup config to the local slot0: and a carriage return is required when naming the file and overwriting the old one.
Cheers.
1 ACCEPTED SOLUTION
Re: Entering carriage returns in Netconfig.
You could always trying using a
The actually means "response to follow".
A without a response means "accept the default". If you wanted to use a different file for a write net, the command would be:
write net192.168.1.1my-rtr.cfg
And if you wanted to acknowledge each prompt explicitly:
write net192.168.1.1my-rtr.cfgy
(compliments of an earlier post)
Hi davistan,
This seems to do the trick, thanks for your help!
Can I just ask where the comes from? Looks like an HTML tag!?
Looks similar to HTML tags, but is actually tags that are used when doing cli configs on devices. have a look at this link:
http://www.cisco.com/univercd/cc/td/doc/product/rtrmgmt/cw2000/cw2000e/e_4_x/4_0/u_guide/netcfg.htm#wp1085251
128
