Error Accessing LMS 3.1
HI All, I am facing issue with LMS3.1. Till yesterday it was working fine but today suddenly its not working we did not do anything on server I dont know why its stop working suddenly. Attaching snap shot of error
Re: Error Accessing LMS 3.1
Post the output of the pdshow command and screenshots of the Services control panel showing all of the CiscoWorks services.
here is the some attachment I will also attach the services of cworks..soon
Post the NMSROOT/MDC/tomcat/logs/stdout.log and stderr.log.
here are the requested files..
Have you enabled a firewall on this server? Can you telnet to localhost port 9009?
No we did not do anything. I checked windows firewall is off & firewall services were running I disabled it now but still its not working.. I am able to telnet to localhost on port 9009. its giving me blinking cursor when i press enter it goes into next line...
it seems working telnet to localhost on port 9009
Post the TomcatMonitor.log.
here is the log file as requested
sorry missed the attachment here it is
It looks like you changed the hostname of this server. TomcatMonitor is trying to connect to cisco1, and this is failing.
we did not change it..there is separate team for server administration..might be they have done it..its customer network are just implementor..now what should be the workaround
I have changed the server name to cisco1 but still its not working...
also just to update you i am getting login screen & when I type user name & password n try to login then its give me forbidden error
Assuming they changed the hostname back to cisco1, and that was the original hostname of the server when CiscoWorks was installed, then have the customer reboot. That should get the services to start again.
If the hostname of the server is now different from when CiscoWorks was installed, they will need to run the NMSROOT/bin/hostnamechange.pl script to change the hostname within LMS.
I have changed hostname back to cisco1 which was the origional one when cisco LMS was installed of lms server but its not working at all..any suggesion
Post the new pdshow, stdout.log, stderr.log, and TomcatMonitor.log.
here are the requested logs
It looks like there is a problem with the System Identity User account. If you cannot log in, you will need to regenerate this account from the command line. To get this procedure, open a service request with TAC.
remaining attachment
here are services of cworks....
224
