11-16-2010 12:53 PM
After logging in, I am redirected to a page https://myipaddress/cwportal/c/portal/login and recieve
HTTP Status 404 - /cwportal/c/portal/login
Type Status report
message /cwportal/c/portal/login
description The reqested resource is not availible
Apache Tomcat/5.5.17
The system was running fine on 3.1, any ideas?
Thanks in advance
11-17-2010 12:59 AM
please post pdshow and installation log.
11-17-2010 06:14 AM
11-18-2010 01:02 AM
You have a lot of processes down. The root cause is that you had some critical errors during the upgrade:
ERROR: This dsn, cmf, already exists. Can not addDsn.
ERROR: [StandardDbRegistration] odbcdsn.pl failed with 256
The best solution is to re-install. But you should clean your server after you uninstall CiscoWorks, e..g. registry, installation folder.
