Error during Uninstalling LMS 3.0
I have got one message, during uninstalling the LMS version 3.0. I have attached the screenshot. please find it and explain me the message.
Bronze
Re: Error during Uninstalling LMS 3.0
IPM needs collectors on the devices to work.
This collectors should be deleted by using IPM. If you uninstall IPM you are not able to delete the collectors on the devices.
1)How can i delete the collectors by using IPM.
2)what devices it specifies(ie) the devices added in the ciscoworks or some other devices.
3)what would happen if i am not deleting collectors on the devices
4)what is IPM?
Bronze
Okay....out of your questions I suppose that you never use the Internet Performance Monitor (IPM) of LMS.
If you never used it in the past you have no collectors on your devices because you have to configure them manually.
And so you can uninstall the LMS, I think :-)
101
