Attention: The Community will be in read-only mode on 12/14/2017 from 12:00 am pacific to 11:30 am.
During this time you will only be able to see content. Other interactions such as posting, replying to questions, or marking content as helpful will be disabled for few hours.
We apologize for the inconvenience while we perform important updates to the Community.
Error mails from HUM
Hello all,
In our company we are using CiscoWorks LMS 3.0.1.
Presently,We are using Hum 1.0.2 version.
If the site is down , we get errors mail for after every 5 mins or 6 mins or 10 mins mins- device availability threshold violation
Error: Router has violated the 0.0 Device Availability threshold
We are getting mails every 5 mins. Timming is not constent sometime we get mails after 5 mins or 10 mins mentioning same site.
Thresold seting in HUM
MIB object name: sysUpTime
Instance Name: Device Availability
Number of violatons: 2
Threshold condition: var == 0.0
Violation value: 0.0
Severity: Critical
we have 4 GB RAM and updated HUM version
Note: If the site is down for 2 days . we got nearly 200 mails .if 4 sites are down then we get 800 mails .
How can we check each every mail. If we mark as all read then we miss some inportant mails.
Is there any way to stop these mails or reduse to some extent ,other wise it will be worse to check all mails.
Please provide the solution for it .
thanks,
ashraf
1 REPLY
Silver
Re: Error mails from HUM
The devices are becoming not reachable after process restart. I think you are hitting this bug CSCsw76838. Please ensure it. Try to reconfigure it HUM and the server.
http://www.cisco.com/en/US/docs/net_mgmt/ciscoworks_health_and_utilization_monitor/1.0.2/user/guide/HUMucase.html
101
