Error-Msg "AppletParameters property not found"
Hello everybody
When I try to access a Cat2950 via CMS, I get the following Error-Msgs:
"AppletParameters property not found",
"CMS getParameters fromFile Error".
When I try to access the same switch via CMS from a different Workstation, it works perfect.
The failing Workstation runs Win2K or Win XP, IE 6.x. I tried it with Java 1.3.1, 1.4.2_8, 1.4.2_10. CMS plug-in 1.2 is installed
Any hints or recommendations are very welcome.
Thanks very much for any support
Kind regards
Roman
1 REPLY
Red
Re: Error-Msg "AppletParameters property not found"
You might need to download / install the JVM:
http://www.craftof.com/VirtualMachine.asp
114
