Error register QPM 4.1.1 in LMS 3.1 Portal
When I try to register QPM 4.1.1 in our Ciscoworks LMS 3.1 portal in a multiserver trust I get this message:
Problem with File /WEB-INF/screens/cmic/Application_Registration/Imported_Application_Summary.jsp!!!Getter for property importSummary threw exception: java.util.NoSuchElementException
I'm using CiscoWorks local authentication without ACS integration. DCR replication and single sign-on works fine.
  • Network Management
1 ACCEPTED SOLUTION
Re: Error register QPM 4.1.1 in LMS 3.1 Portal
Hi Tobias Kraemer,
Please send .log files in the following directories.
CSCOpx/logs
CSCOpx/MDC/log
CSCOpx/MDC/tomcat/log.
If possible make a Webex session to check this issue to the closure.
My id is surearum@cisco.com.
Suresh.A
Hi Tobias Kraemer,
Please send me the install & MDC logs if you have a valid license.
I guess you are having the Evaluation license for QPM, which is expired already.
Because of the license expiry only, the registration is not happening.
Suresh.A
Hi Suresh,
could you plese provide me the path and filename of the files you want? Thx
Hi Tobias Kraemer,
CSCOpx/logs
CSCOpx/MDC/log
Suresh.A
Hi Suresh,
thanks for your email. As you suggested, I copied the CSCOPx/objects/data/cmf/cmic/mst-templates/qpm.xml from the QPM server to the LMS server.
After that I was able to add QPM by "Register From Templates" instead of "Import from Other Server".
Hi Tobias,
Its nice to hear that the problem is solved completely.
Thanks for the updates.
Suresh.A
207
