12-16-2008 12:20 AM
I'm trying to use NetConfig on devices using SSH and I always get this errror.
ERROR:RME_CDL1031:Transport session to device failed SSH: Failed to establish SSH connection to 172.22.0.7 - Cause: Authentication failed on device 3 times. TELNET: Failed to establish TELNET connection to 172.22.0.7 - Cause: Connection refused.
I've only got SSH and TELNET enabled in RME and with SSH as the higher priority.
I've double checked the user credentials I want CW to use in Common Services... Do I need to check on other places? What could be causing this?
Gudvardur
Solved! Go to Solution.
12-16-2008 08:21 AM
Default credentials are only processed when the device is added to DCR. If you added these credentials after this device was added, it would not have inherited the default credentials.
Update DCR so that it has the correct credentials for this device, then you should be set.
12-16-2008 08:32 AM
Select the devices under Common Services > Device and Credentials > Device Management, then click the Edit Credentials button.
12-16-2008 08:08 AM
This error is almost always correct. It points to bad credentials in DCR for this device. You can do a DCR export under Common Services > Device and Credentials > Device Management to view the credentials in clear text. Then, try using those credentials from the CiscoWorks server, and make sure you can successfully get into enable mode.
12-16-2008 08:17 AM
The username and password is empty, how can that be if default credentials are specified?
Do I need to specify this somewhere else?
12-16-2008 08:21 AM
12-16-2008 08:30 AM
This worked brilliantly,
Now one last question, if I need to change credentials for multiple devices in DCR, is there a easy way to do that?
12-16-2008 08:32 AM
12-16-2008 08:35 AM
Fantastic! Thank you so much, jclarke! :D
Merry christmas to you.. :)
11-05-2013 06:20 AM
hello,
i am running the lms under version 4.2.4 and it happens to receive the same error message:
ERROR:CONFIG_CDL1031:Transport session to device failed SSH: Failed to establish SSH connection to .....
I have double checked that the credentials are correct for the failed device using the 1)device credential report and 2)check device credentials . Both of them succeed for the ssh...
Any ideas?
thank you
